Kpackpackkelley
Aug 19, 2013Explorer II
Look in the parts manual at the rocker arm stud make sure the bottom nut is tight against the wall if its loose it will throw the spring and rocker arm off don't ask me how I know.i would set the valves to spec and try another spring. Do you need the service manual.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
