RLS7201
Oct 11, 2016Explorer II
PhrogPhlyer wrote:
Thanks for the info. Managed to squeeze over the top of the generator and found the pump at the right rear. Extremely difficult to get to unless you tip the generator forward at about a 30-45 degree angle (my genset sits on the coach frame, so it has to be lifted out, not dropped).
I was suprised to see that there was a fuel filter attached to the outlet port of the pump. I had thought the only filter was at the end of the gas hose attached to the carb. There was no mention of two fuel filters for this generator. Anyone else see this on their Marquis 7000??
Could it be that you are seeing a fuel shut off solenoid and not a fuel filter, after the pump? That's what I have on my Marquis 7000.
Richard
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
