wa8yxm
Sep 19, 2017Explorer III
Possible suspects are fuel issues, Oil level and the generator section of the assembly....
First: When it stops the LIGHT will blink, note the pattern of the blinks and write it down, It is USUALLY a 2 digit number like 3-2 3-2 3-2
YOu can look up the code but alas can be a tad cryptic
I have a friend who had bad brushes. the unit was not making with the 120vac So the code was "Batteries low or cranking speed too slow" which we knew was NOT the case (That's what I mean by cryptic).
But post the code and if you have it the translation.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
