DiskDoctr wrote:
The guide also mentioned it shutting down if the output or rpms are not correct.
Those should show up in the fault code, so I'm interested to see what it's reporting. Also, turning the breaker on/off shouldn't have any effect, although I've been confused occasionally by making a change and coincidentally, the gen operation also changes at about the same time.
To rule that out I'd wait a while after the gen is running before turning the gen breaker on to make sure that the gen really does run for a while with the breaker off, and that turning on the breaker is really the thing that causes the gen to stop.
