Gdetrailer
Sep 16, 2017Explorer III
jltarley wrote:
I've recently purchased a 1988 RV with an Onan KV spec J 2.8 gasoline. I was able to get the generator running, but it runs rough, and surges very strongly. All research leads me to believe that the carb needs replaced.
The carb in the generator is P# 146-0861. I've had a hard time finding a replacement for less than $300, and there just does not seem to be a lot of them out there. I have been able to find quite a few 146-0569 carbs, which are from previous versions of the same model gen.
Are these carburetors interchangeable? If not, does anyone have any other good solutions for this issue?
There is most likely no "direct fit" carb available, some like Onan are proprietary to that manufacturer.
Now, if you are extremely handy with wrenches, have a good shop full of metal working tools like lathes and milling equipment it might be possible to "fab" your own adapter to a small engine carb like a Honda.
Then the problem there is figuring out how fuel gets to the carb, is it compatible with the fuel pump used, the linkages work, getting the throttle to work with the governor and the proper RPM of the engine.
Now, about this time your are thinking that all is lost..
Perhaps, you should think about trying to CLEAN the carb first before declaring it dead..
Many small engine carbs use a similar setup which uses what is called a "jet", the jet meters the fuel that is taken into the carb throat.. The jet gets clogged and now the engine may run ruff or not at all..
Many small engine carbs you can remove the fuel bowl and access the jet to clean it with spray carb cleaner.
See PAGE 3 IN THIS LINK where I tell how this can be done on a Honda GX series carb which might be helpful to you to figure out if the Onan carb can be serviced.. There is a link to some You Tube vids that may prove helpful..
If your Onan carb has similar design, you might be able to disassemble and clean the jet for the price of your time and a can of carb cleaner..
I hate this "throw away" mentality that is prevalent now days..
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
