10forty2's avatar
10forty2
Onan 5500 Marquis Carburetor Fixed
I have the gasoline Onan 5500 Marquis BGM series with the altitude adjustment on the bottom of the carburetor fuel bowl. I posted a while back about my genset not running. It wold turn over fine, but would never catch and run without me physically holding the choke butterfly closed. I had eliminated spark plug, oil level, fuel lines, fuel filter, air filter and gasoline level in the tank and came to the conclusion that the carb was gummed up from non-usage by the prior owners.
After reading multiple times that Onan carbs are not supposed to be serviceable and shoudl only be replaced for about $300, I ran across one posting online where an Onan mechanic had stated how to gain access to remove the fuel bowl. The black altitude adjuster is removable by using a pair of pliers and some moderate downward force. The button just pulls right off without damaging it. Once it is off, the needle valve assembly secures the bowl and can be removed with a standard .5" wrench.
After removing the needle valve and bowl, I quickly discovered that my assumption was correct...the bowl was full of old gasoline varnish and the needles valve was mostly stopped up. The float was stuck closed too. I soaked the bowl and needle valve in Sea Foam for about 30 minutes and amazingly, most of the varnish dissolved. I used a small, stiff wire brush and scrubbed the remaining varnish from the inside of the fuel bowl and soaked it again in fresh Sea Foam. I gently worked the float back and forth to free it and using a stiff nylon brush soaked in Sea Foam with a gentle touch, I was able to clean the float hinge to where it moved freely up and down to work the float valve properly.
After marking the location of the adjuster for the needle valve, I carefully unscrewed it from the orifice and counted the number of turns it took so I could reinsert it to the original adjustment. It too, was pretty gummed up as was the orifices through which gasoline is sucked up past the needle into the carburetor jet. Once removed, I also soaked that assembly in Sea Foam and lightly scrubbed it against the wire brush to remove the varnish deposits. Another soaking, another brushing, and then several blasts with Gunk brand carburetor cleaner for good measure, the parts were clean. Using a small cosmetic mirror from my wife's makeup drawer ;-) (I'm sure I'll hear about that later), I also carefully shot some carb cleaner into/through the jet inside the carburetor from underneath without removing it. I never saw any varnish there.
After all was cleaned and reassembled, a touch of the start button and the genset cranked over several times before picking up it's prime and BAM...... it started running! A little rough at first as it cleared all the pure carb cleaner and Sea Foam, but once it picked up some good gasoline, it purred like a kitten!! After about 10 minutes of running smoothly, I loaded the generator a little at a time by first turning all the lights on in the coach, next the refrigerator, and then finally both A/C units. It surged slightly when the A/C units' compressors kicked in, but continued to purr steadily for the next hour as I let it run! I unloaded it and let it run for another 30 minutes or so without problems.
WooHoo!! Problem solved for a couple hours worth of time sitting in the driveway tinkering and about $20 worth of Sea Foam, carb cleaner and small wire brushes. Sorry for the long post, but after searching and searching online and only finding the one post about repairing the Onan carburetor instead of replacing it, I figured someone else might benefit from my trial and success!! For reference too, I did find an aftermarket place that has prett good prices on Onan parts as well:
http://www.partsfortechs.com/asapcart/generator-parts-onan-c-14_104.html
I sincerely hope this helps someone in their quest to repair their generator!!
  • About once a year I pour about 7 cans of Seafoam in the gas tank and go on a trip where I will burn a full tank.
    I run my Onan 5500 most of that trip, which is easy to do when it's 100 degrees around here and need the house air conditioning on.
    10 years now and the generator still runs great.
  • The fuel pressure comes from the spring of a spring loaded solenoid/plunger which is cocked a few times a second whether or not it needs cocking. There is no feedback loop to tell the pump enough is enough, it just keeps pulsing the plunger. If there is no place for the fuel to go then the plunger stays in the cocked position with the spring applying pressure to the fuel. etc etc
  • Thanks to the op for the low down on the 5500, congrads on the fix. I have a 5ooo, and thought I might have carb problems, but after replacing a VR, and running for an hour or so it leveled right out, and runs great, after not being run for about 7-8 years, will keep your post in mind. I have heard that sea foam works wonders, but have never needed yet. Geo
  • frankdamp wrote:
    Agreed, Jack.
    My Onan 5500 is dead also, but with the opposite problem to the one the OP had. I thought I had his problem since I hadn't exercised the generator for about 3 months as I was recovering from cardiac surgery.
    I found that the fuel pump was not working, so I replaced it. I couldn't find an Onan part, but got one that looks absolutely identical.
    I now have a problem that looks like high fuel pressure. When I prime it, the fuel pump never stops ticking like the original did and the generator coughs and bangs like crazy when I try to start it. It also spits out clouds of white smoke.
    Next step is to check fuel pressure and, if it's high, to find out if the pump has an adjustment. It'll be hard to sell the RV if the genny is dead.
    If it were me, I'd start out simple and make sure I had reconnected everything securely and there were no air leaks in the fuel line. Sounds more like it's losing pressure rather than being over-pressured. And the white smoke sounds like moisture being burned off.... if it were too rich from too much fuel being forced into the carb, I would think it would be black smoke.
  • Agreed, Jack.
  • While I don't have an Onan generator, I appreciate you reporting back on your generator fix. I wish others would report back when their problems were solved. JMO
