j-d
Sep 17, 2017Explorer II
I found This 146-0705
that claims it works up to Spec J
An expert told me awhile ago that Microlite (KV, KY) carbs are very difficult to clean because of right angle turns in some of the passages.
If you can get it running, load it down, and feed it from a gallon can of fresh gas that's dosed heavy with Berryman cleaner. Run it a couple hours, let it rest while the Berryman soaks in, run again, repeat...
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
