Gdetrailer
Apr 27, 2022Explorer III
No, not a "Microlite".
That is a picture of my 120 yr old engine cylinder.
I was the first in the family to have needed to crack it open to replace the 120 yr old head gasket which had developed some seapage of the antifreeze into the cylinder.
The black stuff is carbon build up which is normal for all engines, where the carbon stops is where the rings stop at top dead center. The top of the piston stops just slightly below the cylinder deck.
Once I removed the carbon, I was able to verify with a straight edge that the cylinder have almost no ridge.
I stopped short of removing the piston since The cylinder most likely has some egg shaped wear and getting the rings back into the correct wear position is very tricky. Engine does need rings and I debated on the idea of replacing them but that would open a new can-o-worms up which requires boring to remove any egg shape and new custom rings.. No off the shelf rings exist for a 5.5" bore..
ALL engines can develop a "ridge" and any ridge developed will not make the piston stick.
You "issue" most likely came from the RINGS getting stuck in the piston grooves. That can happen from excessive carbon buildup and the engine sitting for extended periods of time with no use..
The carbon over long periods time sitting without running hardens like a rock which can lock an engine up.. That is one of the many issues I faced in freeing up my engine without tearing it down and removing the piston..
At 1800 hrs on a air cooled engine as you worked on most likely needed new rings as they most likely were allowing excess oil and blowby to build up carbon in the piston ring grooves..
I have also worked on various 1970's-1980's v8s and inline 6s with over 100K miles and along with some 1960's small aircooled engines, never once had an issue removing pistons from the cylinders without deridging the cylinders or having them lockup due to ridges.
There is zero "need" to randomly pull the cylinder head and deridge.
In the OPss situation for this engine, it is common to have the STARTER GEAR to hang up just enough to interfere with the ring gear and preventing you from turning the engine over.
