Kpackpackkelley
Dec 16, 2013Explorer II
gotsmart wrote:Kpackpackkelley wrote:
Here's your service manual 981-0530c onan service manual.
Before you try to start it anymore open the front and stick your http://www.cumminsonan.com/www/pdf/manuals/981-0530C.pdf hand to the left around the air cowling and turn the flywheel to see how hard it is to turn. If its really hard to turn clockwise its going to be hard for the starter to turn it too.
If you have to pull the starter to check the plastic gear you have to pull the top cover off the gen that's the hardest part you need torques head bits I don't remember the size.
Kpack, your link has 108 pages and includes the 2000W through 2800W KYD gensets. It may be a condensed/combined manual.
This one has 158 pages and is 4000W only: http://www.cumminsonan.com/www/pdf/manuals/981-0503.pdf
:h
To the OP: page 7 of the 0503 link shows how to decipher the model and serial numbers. Here is a Quickstart Guide for RV owners. Here is a spec sheet with a diagram that is a PITA to read.
Thanks I have the manual you posted. I searched and found this one on spec j thought maybe it was a little different. He's got both so that is a good thing.
Sounds like the the starter gear is bad. Those little things are a pain to change out. They have the cheaper versions on ebay of those starters I bought one of them one time and it was a pretty nice little starter.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
