soren wrote:
copeland343 wrote:
Sounds like a bad muffler bearing.
Sorry couldn't help myself.
Maybe look at the muffler to generator connection that might be loose
Nope, bearing is fine, blinker fluid topped off, and it's ready to roll.
On a serious note, the muffler is welded to a stand, of sorts, that floats on these four springs, and the squeak is enough that I'm ready to tear the whole mess out.
Sounds like it is going to be a bunch of work.. But if you can get into where the springs are you could remove the springs and use "universal" exhaust pipe hangers in place of the springs..
These hangers are made of heat resistant rubber so in a sense you will be suspending the muffler from the universal hangers instead of the springs..
LOOK LIKE THESEThere are different universal hanger designs other than the one in the above link.. Just do a search and determine which ones will work the best for your setup..
