I have a 1994 Onan 2.8 KW model KY. It was running great just a couple days ago but now as soon as I let go of the start switch it dies. Runs nice as long as the switch is pressed. The oil is full an...
Check your coach battery charge state and the connections of it.
If the battery is just a little low (but still lots to start the genset) it will not allow it to run since they work on a power in / power out basis. Anything below 12 volts will give you less than 120 volts.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
