LittleBill
Feb 13, 2018Explorer
dougrainer wrote:azrving wrote:dougrainer wrote:kx125str99 wrote:
Hey guys so I finally had some time this weekend to get to storage and tinker with the generator. Ended up adjusting the idle screw. Runs bitchen now. Thanks for all the help guys.
1. Idle screw problem would NOT allow it to run 10 minutes and then die
2. You NEVER have to mess with the Idle screw at all. It is preset to a specific RPM(3600) and changing it will allow the voltage to change
3. It ran OK before Oil change? I doubt you messed with the Idle screw on a simple oil change.
4. While you THINK you found the problem, you have not. You need to check the NO load 120 voltage now, before you burn up any appliances. Doug
LOL, mind reader.
Not a Mind reader. Just KNOW what I am talking about and a Governor or Idle screw adjustment will not cause or fix the OP's problem. Whatever is wrong with his Genset, fixed itself, because changing the oil would not really cause his problem unless he failed to put the required amount of oil or overfilled the oil. Question, If you took your Auto to an oil change place and they changed the oil and then the Car died every 10 minutes and they stated they adjusted the idle screw and that fixed it, would you REALLY believe that fixed the problem? Doug
most people have no sense of troubleshooting and or are extremly gulable, i once told a girl i was dating that her tire just fell off, while we were driving at 70mph. 0 issue nothing, she almost flipped the car over trying to get pulled over and was hysterical.
needless to say i don't make that joke anymore....
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
