DrewE
Feb 13, 2018Explorer III
kx125str99 wrote:
Well when I was adjusting the screw I could hear the engine noise change. It got quieter so I’m gonna go ahead and jump off a limb here and say maybe it was over revving and going into a safety. Iv only had trailer for about 6 months. . When microwave would run it sounded the same as idle. No change. But now it runs like it should. Revs up when under a load. So I’m gonna gonna stick with the idle screw fixed my issue.
The Onan 4000 watt generator is supposed to run at a constant speed of 3600 rpm, not "rev up" under load—unless by that you mean getting a bit louder while running at (very nearly) the same speed. Since it's a mechanical governor, it will be running at a microscopically slower speed under load, but only a barely noticeable difference, maybe a few percent.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
