- TEXASExplorerThe simple things will bite you.
- wealthwiseExplorerWell problem solved, I forgot to open the second liquid valve, I changed the plugs, the points were bad in them, anyhow as soon as I opened the liquid valve it started up. Thanks for all the help.
TEXAS wrote:
That is a two cylinder. May or may not have points. Need your full model and serial number. The life of it depends on how you take care of it. I have seen some with five thousand hours.
I got a better look at the front of the unit and it's actually,
a Onan Marquis 6500 LP
Serial D933020948
Hope this helps
Thanks - wealthwiseExplorerOk I will see if I can get the serial #, not sure about points, it does look like it has a coil,if that helps, the front plug can changed with no problem, it's the in the back that's tough to get to, is some kind of tool that might fit in horizontally without having to drop the unit? I seem to remember some kind of long ratchet for challenges like that.
- TEXASExplorerYou need to change both plugs.Since it is a low hour unit. I would check the fuel supply system. There was a problem a few years back. With oil from the propane tanks getting into the system gumming everything up.
- TEXASExplorerThat is a two cylinder. May or may not have points. Need your full model and serial number. The life of it depends on how you take care of it. I have seen some with five thousand hours.
- wealthwiseExplorerIt's an Onan Emerald Plus or III, LPG, with 169 5/10 hours.
Thanks - wealthwiseExplorerOk I get it, not enough info, will look for the manual and specs and check the meter and post back
Thanks - naturistNomad IIYou can count on it to run until it quits.
Not trying to be a wise guy, but there's not enough information in your question to even begin to hazard a Scientific Wild-A**ed Guess. What model, how old, how many hours on the ticker, when was it last run and for how long, when was the oil last changed, and maybe a SWAG could be offered.
But no guarantees.
Oh, wait, you asked " … how long can I COUNT on it to run …. " On that basis, you can't. - TEXASExplorerWould help to know what you have.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
