Generator_Jim
Sep 04, 2014Explorer
Had a problem with the gas version of this unit. Turned out to be one of the gaskets between the carb and the cylinder head. Bolts were loose due to vibration and caused vacuum leak preventing adequate fuel mixture for starting.
If very high hours on unit and liquid withdrawal, check if oil is interfering with the fuel solenoid. Propane can precipitate oil out at the point of vaporization.
JimL
JimL
