kehale's avatar
kehale
Onan Propane Genset issue - won't stay running
Background: Gen has been excercised every month or two for about an hour with the AC on/off (loaded).
I let it sit for two months this time. Propane is on and functioning in stove, fridge, and LP vent (BBQ)
Problem:
Generator will start as normal, but when I release the switch, it shuts off.
I've tried unplugging/plugging shore power, but the same thing happens.
It will run as long as I'm holding the switch to "start".
Any ideas?
(vent tube has no mud-daubers...)
  • Handbasket wrote:
    Sounds like your Onan is not self-generating ignition voltage. The little ones like yours and mine (Microlite 2800) get cranking and ignition voltage from the battery as long as the start switch is held down. Once the switch is released, the Onan makes its own. This is the same whether gas or LP; your 2500LP is the 2800 derated for LP. I'm 95% sure you do not have am oil level switch.
    If you have a failure of the voltage regulator, brushes, or rotor/stator, you'll have the same symptom... starts, but only runs with the switch held down. The service manual will have a series of steps to determine what it is, but they require a volt-ohm meter (VOM).
    Your most likely failure is the voltage regulator, about $225 from Flight Systems (they also have some troubleshooting steps online). On my 2800 and probably your 2500, it's a small cigarette-pack sized box, located just out of sight under the engine's cylinder. It's mounted to the engine's base pan with one Torx screw. It's out of the direct line of sight, but can be replaced without pulling the generator.
    Good luck with it.
    Jim, "I drink coffee for _your_ protection."
    It was a voltage regulator problem. Changed it and all is good.
  • I am having the same issue the gen will run fine one day and then will only run if button is held down the next. Whats funny is it ran fine everyday the temp was below zero and then when the weather warmed up it would not start again. Took the camper to onan and it started right up and they cannot duplicate the issue. I cannot find the onan lp 2500 service manual online anyone have a link or can send via pdf
  • I went to onan today to pick up camper and sure enough gen would not start for me. Brought out service manager and now they are looking at issue.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
