Mlbtwp's avatar
Mlbtwp
Onan Quiet 7.5 Diesel Generator Oil
Doing Oil/Filter change on above generator.
Any input or comments with the use of Mobile DELVAC 1300 15-40 engine oil in the Onan generator?? Or other recommendations.
Located in the NW U.S. And planning on multi-climate road trip full U.S.
Mike
  • lj2654 wrote:
    The Delvac oil is a great oil, as is the Shell Rotella. I use the Shell Rotella T3 15w-40 oil in everything I have, etc: CAT engine, generator, truck, mower...
    X2
    X2
  • The Delvac oil is a great oil, as is the Shell Rotella. I use the Shell Rotella T3 15w-40 oil in everything I have, etc: CAT engine, generator, truck, mower...
  • Thanks for your input gentlemen. The Delvac 1300 is the heavy truck and off-road use oil. Specs check out for the Diesel equipment so feel it would work great for all conditions that a Diesel Generator can be put thru.
  • Thanks for the clarification. Nice to know I'm not wrong about everything, regardless of what my spouse says. :)
  • fj12ryder wrote:
    rv2go wrote:
    I am not familiar with Mobile DELVAC 1300 15-40 engine oil.
    I use Rotella T6 15-40 non-synthetic, the same as I use in my Cat 3126.
    I think Rotella T6 5W-40 is full synthetic, Rotell T3(Triple T) 15/w-40 oil is non-synthetic.
    I've never heard of Rotella T6 15W-40 non-synthetic oil.
    I stand corrected, I'm using T3 non-synthetic, not T6.
    Bill
  • Excellent oil and it's what I use in my Dodge Cummins truck engine. You should be fine. Wally World usually has it on sale for around $11/gallon.
    I used to use Rotella TTT, but the results I was getting back from Blackstone Labs seemed to show that the oil was breaking down fairly quickly and it was showing some engine wear. I switched to Delvac 1300 and the reports are now showing excellent oil stability and reduced metal particles, i.e. less engine wear. So I'm sticking with it.
  • I am not familiar with Mobile DELVAC 1300 15-40 engine oil.
  • I run the same oil in my Onan 7.5 as in my Cat C7 engine - Rotella T6 15-40 non-synthetic. Using one oil keeps you from making mistakes.
    Bill
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
