Mr__Coach
Jun 09, 2013Explorer
OK you all, tell me if I'm just being paranoid or is it something I should really look into. Since I've gotten this rig here are some of the problems that I've been having and could be leading up to why my Gen. is not running..
1. Code 46 out of Generator (low voltage) If you read on my O/P you'll see what I've all checked.
2. My passanger electric seat is not working (no power to seat) Can't find where the power wire leads to and going to have to run a jumper wire from the drivers seat to power up the passenger seat.. This did work when I first got the rig but now not working..
3. Rear view camera not working. Pulled the camera off the back and pulled the monitor out to take it in to an electronic repair facility and they claim that both the monitor and camera are working fine..
My question:
Is there a pattern here?:h IT would seem to me that somewhere between the back of the coach to the front we have a problem, would it be coincidence that those three items are failing and all of em come from the rear to the front. Other than those three things everything works just fine...Would these three items have anything in commin? Like a fuse,connector,anything else??? Where should I look?? I'm kind of at a loss..Any ideas?
My question:
