theoldwizard1
May 16, 2020Explorer II
enblethen wrote:
Someone needs to calculate your house's load which you plan on connecting to genset. You need to specify exactly what Onan genset you have, model!
You can get a genset transfer switch from many big box stores.
Transfer switch kits
CarolynandBob wrote:
I have an electrician that is going to handle all of that.
I don't like those Reliance/Generac kits. You have to decide up front exactly which circuits you want to use in the case of a power outage.
Automatic transfer switches, by code, require a generator capable of handling the entire house load, including A/C ! (Unless the transfer switch has "load shedding". More complicated, more money)
I highly recommend a generator interlock. Not too expensive and easy to install. All of the circuits in your house remain active and you decide what items to turn or off before the generator breaker trips !
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
