wa8yxm
Sep 18, 2021Explorer III
Yes. if it shuts down (READ THE FINE MANUAL FOR SPECIFICS) you can press the stop stich. I forget how long but I think it's a tap.. And the active light will flash.. ONE of the fault codes is exhaust over temp
You read the codes (The repeat over and over)
if one code you will get like 3 blinks. 2 blinks 4 blinks . . 3 2 4
if two (Or more) 3 2 4... 2 4 2.. 3 2 4.. 2 4 2.. And so on.
Then you RTFM and.. Well sometimes the code helps. (Sometimes not so much)
