D_E_Bishop's avatar
D_E_Bishop
Onan starts and dies, throws Code 3
We hit a heat wave and had to run our generator an Onan (HGJAB901A), it quit and threw a Code I believed was "Low Oil Pressure", I assumed it was due to low oil level and refilled. Now it just starts, runs for 10 or 20 seconds and dies and throws a code 3. I didn't have the manual with me yesterday when I refilled the crankcase and tried to start so I forgot how to check for the second level code.
I'll go back maybe tomorrow but is there a reset or does the low pressure limit switch automatically reset if it shut off due to low level?
Yes I have searched to forums but to no avail, if anyone searches and finds a similar post, please include the search wording used.
  • UPDATE I reread the codes, Flashes Fault Code 3, press STOP, Flashes Fault Code 23, Oil Pressure Fault Switch.
    I followed the trouble shooting instructions and no problems detected. I also changed the filter and oil and I disconnected the Low Pressure Fuel Pump hose and the pump is working well.
    Right now I feel the problem is in the control panel which is behind the carb and air intake and which I believe will require removing the entire generator. It is a pretty simple job but if I did that, I would be at the end of my knowledge. I would assume that a Onan authorized repair shop would also just change the control module or PC board or what ever it is called.
    I would have to build a cradle to rest on my floor jack that would support the four corners of the generator. Too big a job and I have no space to do the work. I would have to do it in the street in front of the house and the DW would not like that.
  • Fault 3 is a general code that indicates you need to check for a secondary code.  After it does the 3 flashes, hit the off button only once and a secondary code will pop up.  I'm having that issue right now with only 40 hours on the generator.
    Your crankcase should only be filled halfway between "ADD" and "FULL".
    • way2roll's avatar
      way2roll
      Navigator II
      Not sure if you are aware but you are responding to a post that's 7 years old. OP hasn't been on here in some time.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
