tpi
Jun 25, 2016Explorer
Do you have a way to monitor voltage during the recharge? If the converter is putting out 14.3 to 14.5 volts, you will be closer to getting the 50 amps for a longer period of time into your trolling batteries. Problem with these converters is they may select a lower charging voltage of 13.6 ish which charges the batteries much more slowly.
