dhust
Sep 02, 2015Explorer
I have a TPMS sensor in 1 tire that went out, but I figured I'd wait until I replace the tires to think about getting it fixed. I found out which one it was by using a procedure to "rediscover" the sensors. I searched online and found the magic codes, and I'm sure it is different for every vehicle so try to find it for yours. Mine went something like turning the key on (not starting the vehicle) and off 5 times, pressing the gas pedal on the last time, and the horn would magically sound. The display would tell you which tire to go to, and you'd have to place a strong magnet around that valve stem until the horn sounded again. If eventually sent me to the sensor that wasn't working, and it couldn't find it, so I now know which one is the problem.
See if you can find some magic codes to help you "rediscover" the sensors, as that may be all the problem is.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
