BFL13
Oct 03, 2014Explorer II
You can monitor one at a time for AH etc. If you are swapping banks back and forth with the giant switch, then if you can arrange the wiring that the Tri swaps too (very tricky) you can reset the AH as soon as you swap to the now full bank to operate from and do the recharge on the now disconnected bank.
Otherwise you are stuck with the Tri on the bank where the shunt is. I am unsure if the Tri pos needs to be on the same bank as the shunt to power the Tri itself.
The switch on the shunt to battery neg posts would have to be a high amp switch to take the high amp loads (and charging if you ever recharged when connected)
