camper1083's avatar
camper1083
Only 50 runs all outlets
I've been camping for decades and this is a new one for me. Just purchased a 2012 KZ fifth wheel with 50 amp service. When I first purchased it and plugged it into my house service via 20amp connection, all the outlets and devices ran properly. Then one day, only half of the outlets worked. Figured I messed something up UNTIL I camped at a campground with 50 amp service. Plugged it in and all was well. All outlets and devices worked. Next weekend I camped at a place with only 30amps. Plugged in using the appropriate 50am to 30amp plug and ONLY half of the outlets worked again. What is going on? Thanks!
  • I'm perplexed as I see tons of 50 amp coaches at 30 amp parks and they don't have this problem. I understand the electrics behind it but all my other coaches ran fine on 30 amp. This problem seems bigger than just a single pole vs dual pole stuff.
  • I like the loose wire at breaker concept, but it's just so consistent. If I'm not on 50 amp only one side works.
  • Loose wire on one breaker. Makes and breaks contact?
    CHeck terminal at breaker panel. Pull on each wire see if one comes out of breaker screw.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
