CptSydor's avatar
CptSydor
Only kitchen faucet won't flow.
I've searched, but can't seem to find this exact situation, everything seems more global.
After de-winterizing my trailer a few weeks back, I was flushing the lines and all the faucets (kitchen, bathroom, shower and toilet), both hot and cold were flowing just fine.
I got sidetracked and a week later I went back and directed water back into the hot water heater.
From my recollection, it seems that after I filled the hot water heater, my kitchen faucet started spurting, and now does nothing. Both hot and cold water. Not sure if those two things are related or not.
I was just back out in my trailer. I hooked up city water, the kitchen faucet dribbled a little water, then dead again (my city water feeds almost directly into my kitchen faucet for cold). No apparent leaks anywhere.
My faucet has both a hot and cold on/off.
All the other faucets/toilet, both hot and cold are working from both city and the fresh water tank.
Any ideas?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I see you solved your problem but I will tell you of another.. This applies only to those kitchen faucets where the head pulls out and doubles as a sprayer.
    There is a check valve in the head where the hose connects.. It too clogs up.
  • Also cleaning your water heater will help remove sediment. I do mine once a year, but I do not winterize.
  • Probably stirred up sediment in the water heater when it filled up which in turn blocked up the aerator.
  • Would you think that when you filled the wH, that it washed the sediment off the bottom and right into the faucet ?
    Does that say its been a while since you drained the WH ?
  • ppine's avatar
    ppine
    Explorer III
    Often there are little screens in the water lines connected to the faucet. Take it off, clean it and check the screens.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 28, 2026
