enblethen
Oct 01, 2020Nomad
After seeing photos, No the adapter will do no good.
You need the correct male range plug on the shore power cord then if wired correctly to panel it would work.
The receptacle in the photo needs to get wired correctly if that is the one to the expresso machine. Parallel blades are the power.
