jeff_1981
Oct 01, 2020Explorer
enblethen wrote:
After seeing photos, No the adapter will do no good.
You need the correct male range plug on the shore power cord then if wired correctly to panel it would work.
The receptacle in the photo needs to get wired correctly if that is the one to the expresso machine. Parallel blades are the power.
This is a picture of the actual receptacle on the outside of the camper trailer: https://drive.google.com/file/d/1qJirz6rJ9OUwniTEEF0FBqXgV7kAqqyy/view?usp=sharing
Is that what you need to see? Assuming it is wired correctly...what type of cord or cord/adapter combo do I need? I'm struggling to locate the right item....
Thanks so much. Really appreciate your help!
