CA Traveler wrote:
myredracer wrote:
ScottG wrote:
Oddly, GFCI is not required by NEC for a "Trailer" 30A supply or even a RV 50A outlet.
I've often wondered about that too. Cost is around $40 retail. When it comes to residences, they now call for GFCIs and AFCIs on just about anything they can think of. The NEC code writers don't seem to pay the attention to the RV world it deserves.
My guess is that there are to many appliances like A/Cs etc that cause GFCI's to fault.
Can someone shed more light on this?
My 11 year old house has one GFCI circuit and 3 AFCI circuits. None of the dedicated 20A plugs in the house or garage have either as well as none of the 120/240V circuits.
I'm suprised your bathroom outlets aren't on a GFI, likewise for Kitchen.
Not sure about 11 years ago, but
NEC code in the past and maybe currently, allow fridge and freezer circuits to be non GFI even if they are in a location requiring GFI circuits. E.g. kitchen. the solution is to use a regular breaker with the first outlet going to the fridge/freezer and then install an outlet GFI on the next outlet in the circuit.
and yes, motor driven devices are known to trip a GFI due to inductance to ground. that's why the exception for fridge and freezer.
although I believe current NEC requires all outside outlets, bathroom outlets, and kitchen outlets be protected by GFI. It may even now extend to garage and laundry rooms. Bathroom and outside outlets were required by NEC to have GFI protection at least as far back as 1978 when we built our house. Kitchen GFI requirements were added after that.
But local codes vary as well and don' always follow NEC.
AFCI's are currently requred in all bedroom outlet circuits IIRC.
given the low cost of outlet GFI's and the benefit, in our house I have upgraded all our outlet circuits to GFI's. easy to do.
One warning, a GFI will NOT prevent all possible electrocution hazards. For example if I have on rubber soled shoes on dry surface and get across the hot and neutral with both arms, good chance the GFI won't trip. In this case there likely would not be enough leakage current to a ground to cause an imbalance.
