I have an open neutral as indicated by my surge protector. I have checked my recepticles with a tester and verified. I have used a multimeter and found the problem seems to be coming from my converter...
You are mixing up a converter with an inverter! A converter changes 120AC power to 12-volt DC. An inverter changes 12_volts DC to 120-volt AC power. Your surge protector is telling you that the power between the rig and shore power source has an open neutral. Are you sing an adapter? Are you connecting to 30, 50 or 15/20 shore power?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
