Skyhow1ExplorerSep 11, 2022Open neutralI have an open neutral as indicated by my surge protector. I have checked my recepticles with a tester and verified. I have used a multimeter and found the problem seems to be coming from my converter...Show More
CA_TravelerExplorer IIISep 11, 2022There are also combined charger/inverters, and these units also require AC input. Converter is also a slang term for charger or battery charger.Maybe this helps:Pedestal>EMS>CB Panel>charger/inverter>some outlets and other variations.Normally a "surge protector" ie EMS indicating open ground is before the inverter and hence can cause down stream issues.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
Related ContentOpen Neutral and failed transfer switchOpen Neutral 30 amp serviceOpen Neutral on new 2023 Keystone SprinterOpen Neutral and Fridge says ANeutral lines reversed
