I have an open neutral as indicated by my surge protector. I have checked my recepticles with a tester and verified. I have used a multimeter and found the problem seems to be coming from my converter...
Have you (or prior owner) by any change installed an inverter that does not bond it's output AC neutral and ground? Where are you detecting the open ground? At a EMS or plug?
