ScottG
Nov 21, 2019Nomad
If you're going to use your propane furnace, you'll be fine. The fan uses less than roughly 60 watts, the fridge about 325. Water heater might push you over if run on 120VAC. If you're not worried about pipes freezing, you could get away with a space heater set to run at 750 watts. That would save a lot of propane.
Otherwise, you wont have any issues.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
