opnspaces
Nov 21, 2019Navigator III
Seriously you'll be fine even running the air conditioner. Just be aware that you can't run two high wattage devices at the same time.
High wattage devices:
You probably won't be using the AC so that just leaves two devices to be aware of. If your water heater is on electric then turn the switch off before you use the microwave. Other than that just don't worry about the electric uses and have a good time. @0 amps is plenty of power for your coach.
- Microwave
- Air conditioner
- Water heater on electric
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
