twodownzero
Nov 22, 2019Explorer
A 20 amp 110 volt circuit probably has close to 100 times the amount of power available that I used on my most recent trip (solar, 12v, dry camping for ~5 days). You will be able to run your gas heat and water heater and electric fridge indefinitely on that much current. You might be surprised to learn that you seldom ever draw that much current from the grid even at your house unless your A/C is running, you're using big tools/welder/air compressors etc. Even with the use of your air conditioner, as some say above, as long as you didn't use any high draw devices at the same time, 20 amps is plenty.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
