- MEXICOWANDERERExplorerThe "kit" of my making includes a new thermostat housing with an N/O temp switch bonded to it with JB Weld. Teflon 2/22 dual wire. And a flanged piezo emitter to hang under the dash. It is tiny. A single 22 gauge power feed wire with 1 amp fuse. The secret is a 10-second 'till off enclosed timer circuit. It resets.
I just do not understand why audio alerting is ignored. The word ignored commonly is associated with another - ignorance. - MEXICOWANDERERExplorerAre 200F thermostats available for these engines?
- red31ExplorerNew water pump brought my scanguage water and trans temp down, dash gauge went up, 07 Colorado!
- pianotunaNomad IIINo the gauge is in the normal range--but I'm using a scangauge to display the temperature.
time2roll wrote:
190 to 240 is normal. Does the gauge move? - pianotunaNomad IIIThank you.
MEXICOWANDERER wrote:
Don, I will send you a complete kit to install a 230F audible alarm that will not fail. The alarm is a chime tone. Use electrical tape over the tiny speaker to throttle the volume. The trigger mechanism has a service life of 10,000 actuations at full 27 amps. This circuit uses 20 milliamps when alarming.
I don't give a **** how "hot" people claim is "safe". The difference in the life of hoses and seals dumps on its butt at higher temperatures and increasing temp from say 200F to 230 does not improve emissions or fuel mileage. What is DOES do is NOT allow transmission fluid to cool as well. - 2_many_2Explorer III
Sounds pretty neat, details on kit? - MEXICOWANDERERExplorerI love the asterisks. It takes a mild four letter DAM and gets people to use their imagination to turn it mentally into SH** or even FU** Great foresight.
- MEXICOWANDERERExplorerDon, I will send you a complete kit to install a 230F audible alarm that will not fail. The alarm is a chime tone. Use electrical tape over the tiny speaker to throttle the volume. The trigger mechanism has a service life of 10,000 actuations at full 27 amps. This circuit uses 20 milliamps when alarming.
I don't give a **** how "hot" people claim is "safe". The difference in the life of hoses and seals dumps on its butt at higher temperatures and increasing temp from say 200F to 230 does not improve emissions or fuel mileage. What is DOES do is NOT allow transmission fluid to cool as well. - Yup! 190 to ~240 is normal so it does not move. I have seen mine move and it was not too late. Just slow a bit and it goes back to normal.
Just a lot of disagreement on how hot is hot such as this old blog post:
http://www.intellidog.com/dieselmann/b_smoke13.htm - MitchF150Explorer III
Not if it's a Ford.... They don't move for sh** until it's too late..
That's the only thing I hate about Fords.. Their gauges suck as far as telling you what is actually happening..
Even on my 13 F150, the actual gauges don't move once they reach operating temp.. They are just there to give you a false sense of security that "all is good"... Since the needles don't move...
I'm sure they will move, once you are overheating... But, what good is that?
Anyway, at least my 13 has an actual trans temp mode on the display, so I can monitor that... I've seen it go to 230 on the display, but the actual "gauge" didn't waver a bit from when it's running 195 in the dead of winter..
I know why they do this.. But, for us folks that actually know how to look at a gauge and not panic when it moves....
Mitch
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 28, 2025
