ewarnerusa
Nov 27, 2014Nomad
Do those of you who are instructing me to check battery voltage with a multimeter doubt the accuracy of the voltage sense readings? I don't refute the ultimate accuracy of a multimeter reading across the posts; however, the purpose of the voltage sense wires is to have a continuous reading of voltage across the battery posts that the controller can monitor to ensure the proper setpoint voltages are being realized at the battery. This acts to compensate for any voltage drop and loss issues due to wire lengths, resistance, etc.
From the manual,
"A battery voltage sense connection is not required to operate your TriStar
controller, but it is recommended for best performance in all charging and load
control modes. The battery voltage sense wires carry almost no current, so the
voltage sense input avoids the large voltage drops that can occur in the battery
power conductors. The voltage sense connection allows the controller to measure
the actual battery voltage under all conditions."
also,
"Battery Voltage Sense: Connecting a pair of voltage sense wires from the
controller to the battery is recommended. This allows a precise battery
voltage input to the controller and more accurate battery charging."
From the manual,
also,
