TakingThe5th
Feb 27, 2017Explorer
I would go with a Suburban gas/electric model. Old-Biscuit's Suburban numbers shows a 50% better recovery rate (BTUs) over the Atwood. If you run the propane and electric simultaneously then recovery will be impressive. Buy the largest heater that will fit in your space and you'll have a good amount of nearly continuous hot water.
Also spend a little time looking at your shower head. You might want to upgrade to something more efficient with water usage. We like our Oxygenetics-it mixes air in with the water to give more flow volume while using less water.
