notruffinit's avatar
notruffinit
OTA Antenna questions
I am set up in Des Moines for the weekend and have a problem with my TV antenna reception. As a result, I am looking for suggestions on what might be my problem.
I have cranked up the antenna, I have made sure that the booster is set for antenna and not cable. I do not fully understand the booster display, but it appears that I have reception. When I auto-search for stations I only get one station on both the televisions. I know from experience that I should see about 15. I did not find any stations at the last campground, but I was unfamiliar with the area and wrote it off to where I was parked. Before I left home a few days ago, I had all the stations that I should have seen.
All connections were checked. All settings on BOTH televisions are set to ANTENNA as is the signal booster. I am inside the city limits where I should be able to pick up all the networks without even cranking up the antenna.
Now my question, where should I start my search for a remedy? This will not ruin my trip because I have better things to do than watch the tube, but I do like to watch the news at night.
  • Lynnmor wrote:
    I understand that, but all I need is a source, make or model number of a product that someone has tested with a TV. If you could point me to such a product, then there would be no need to waste time and money to test different products.
    Here is one eBay store; check out the different products they offer.
    Taken from: "My LEDs".
  • Sorry. Don't mean to interrupt your conversation on LEDs.
    OK. So I got an external antenna and hooked up my TV. I got 15 channels right off the bat. I guess the problem must be in the signal booster.
    It could be the booster or a bad connection; the power to the booster is fed through the co-ax.
    You were asked if you use LED's, and you never answered that.
  • RoyB's avatar
    RoyB
    Explorer II
    LYNNMOR - Does my heart good to see someone having RFI from LEDs. I thought I was the only one haha... Just about every regulated type LED lamp I found would create enough RFI to blank out my OTA reception of HDTV signal...
    Most folks say theirs works just fine >>> go figure...
    Roy Ken
    No
    I have the winegard SensarPro and it is powered. I will keep investigating. Thanks all for the suggestions.
  • Does your coaxial off the antenna amplifier plate go to a switch-box and then the TV?
    If so, disconnect the coaxial cable going to the switch-box and connect it directly to the television coaxial input. Make sure the amplifier is turned on (LED is lit). Now set up television to "antenna" and do the auto-search.
    If the stations are found the problem is the switch-box (wrong buttons pushed/bad cable connections/or otherwise).
    Did you remove the amplifier-plate screws, and pull the plate slightly away form the wall to make sure the coaxial-cable is tightened correctly to the back of the plate power injector? If not no power to antenna amplifier or good signal connection.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
