notruffinit's avatar
notruffinit
OTA Antenna questions
I am set up in Des Moines for the weekend and have a problem with my TV antenna reception. As a result, I am looking for suggestions on what might be my problem.
I have cranked up the antenna, I have made sure that the booster is set for antenna and not cable. I do not fully understand the booster display, but it appears that I have reception. When I auto-search for stations I only get one station on both the televisions. I know from experience that I should see about 15. I did not find any stations at the last campground, but I was unfamiliar with the area and wrote it off to where I was parked. Before I left home a few days ago, I had all the stations that I should have seen.
All connections were checked. All settings on BOTH televisions are set to ANTENNA as is the signal booster. I am inside the city limits where I should be able to pick up all the networks without even cranking up the antenna.
Now my question, where should I start my search for a remedy? This will not ruin my trip because I have better things to do than watch the tube, but I do like to watch the news at night.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
