2oldman
May 04, 2017Explorer II
brulaz wrote:You should have a 24v shore charger. Your setup is becoming too complicated otherwise. The Victron should be handling all the 12v loads.
Also know the 120VAC-12VDC converter doesn't require batteries, but will it interfere with the 24-12VDC converter. Should I turn off the 24-12VDC converter when on shore power?
BFL13 wrote:Yes.
I figure a 24v charger is required, powered by 120v shore power or generator.
