brulaz's avatar
brulaz
Other 12V Sources with a 24V-12V converter
Switching to a 24V battery bank has gone well so far. The 40A Victron 24V-12V converter seems to handle all my 12V loads without issue. It keeps the V at about 13.2V
But a question: there can sometimes be other 12V sources, like the 120VAC-12V converter when on shorepower, or the truck's 12V alternator source when towing, or even the little 10W solar battery tender that came with the trailer. These are all wired into the 12V side and do not now see any batteries.
Would you expect any conflict with the Victron 24V-12V converter, or any issues because of no 12V batteries?
I know my mppt solar charger goes a little crazy when no batteries are present. It's scan to determine the mpp will send Vs all over the place. But it's now tied into the 24V battery bank and is happy.
Also know the 120VAC-12VDC converter doesn't require batteries, but will it interfere with the 24-12VDC converter. Should I turn off the 24-12VDC converter when on shore power?
Should I also let the truck's alternator handle the 12V loads by turning off the 24-12VDC when travelling, or just disconnect the alternator's feed to the trailer? I've already disconnected the little solar panel. The truck's alternator feed is harder to get to.
Thanks.
  • In my opinion, you should FINISH the conversion by disabling all the "old" 12 V charging sources. Eventually one of them will cause you pain and confuse any troubleshooting you try to do.
    I say "disable" because they might come in handy later.....for exactly what I don't know.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
