teeznu's avatar
teeznu
Outback 80-Flexmax Charge Controller-HELP
As you can imagine, we've got solar on the roof of our MH. Been installed for a couple of years. All has worked well....UNTILL now.
Checked the charger yesterday just to give it a "peak-see". And what I saw was NOTHING. LED display was dark. No readout. Breaker's were still in the ON position so I turned them off and then back ON. Nothing. It's extremely windy here in Tucson today so I doubt I'll be on the roof to check wiring connection points. Perhaps later I can check battery connection points but this would probably be a mute point because the battery connection points are "after the fact" from the charge controller. Quick start guide doesn't offer much help.
So I turn to you gurus of Solar Technology. Thank you all in advance for your suggestions.
  • "... because the battery connection points are "after the fact" from the charge controller.."
    Nope. The battery connection comes first to power up the controller. Then you connect the array after that.
    Ought to be a fuse on the wire from the positive controller terminal that goes to the battery positive, somewhere close to the battery. Check that fuse. If blown, have several spare fuses while finding out want blew the first one.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 03, 2026
