frosty1_4me's avatar
frosty1_4me
Outside faucet only hot tap works
This is pretty odd. The outside tap on my Tracer 3000bhd (forest river brand) only has the hot tap working. I took apart the faucet and still the hot water tap when I turn on the pump works.
No cold water at all. There is a hex nut in behind the faucet assembly down in the collar a ways but I don't know if that would make a difference. It worked fine last year and if I have the hot tap turned off and the cold tap still without the assembly the pump kicks off. So it's not a burst line, I can't see any water anywhere and if it was broke the pump would run.
I looked under the bed and lifted the storage area to see the line and it looks fine.
Do I need to pull out that hex nut? Is it a valve back there that could be stuck?
I'm at a loss.
Thanks.
  • wnjj's avatar
    wnjj
    Explorer II
    Is there a winterizing shut-off valve anywhere else that maybe isn't on?
  • Sounds like a faulty faucet.....
    Disconnect cold water supply line at faucet...turn pump on...get water?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
