Oasisbob's avatar
Oasisbob
Oven ?
We use our oven often. Last trip out The pilot lit fine but burner would not ignite until I blew air through a straw near pilot lite area then all was fine. How does one clean out these little openings? Is there an easy way? Anyone know what is going on here?
  • I know it takes a few for the thermacouple to open the gas to the burner. Last trip after a full five minutes it took blowing air back to get it done. So do you just clean the burner with the tooth brush? What about carb cleaner with gas off?
  • An old tooth brush. I sometimes have the same problem. I light the pilot light with a long butane bar-b-que lighter and if it doesn't light the burner right away I'll hit the burner with the lighter. The problem I think is it takes a minute for the thermocoupler heat up to open the valve.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
