arcsum68 wrote:
dougrainer wrote:
Need Brand and Model of Oven. There is a non published TSB on I believe Atwood ovens where the problem is what you describe and it involves replacing the Pilot assbly. NO adjustments would fix this problem. Doug
Suburban SRNA3, sounds like this is not an issue for mine, but thanks for mentioning it. I did hear about some recalls for my brand but havent found anything specific.
UNPUBLISHED! You will have to contac Suburban with Model and serial number and explain what it is doing. They then may send out the replacement part. Or send it to a Service center if yours is that problem. Doug
