arcsum68's avatar
arcsum68
Oven Going Out / Thermocouple
Hey all.
Did some searching and found tons of posts where people have the same issue that I seem to be having where the oven will light perfectly fine and then go out. The general consensus seems to be that either the pilot light is not big enough, or the thermocouple is not in line with the flame and gets blown out when the main burner comes back on to bring the oven back up to set temp after the initial heating process. I looked and do not see any adjustments for the pilot light, and the flame and the thermocouple do appear to be in line with each other, though its difficult to tell and I am not sure just how perfect it needs to be.
I will take any advice, but I was wondering if the thermocouple itself could still be the problem. Do these things work intermittently? My trailer is a 2014, however it was only used a handful of times before I bought it and the oven looked like it had never been used. The fridge and thermostat still had the factory plastic protectors on them!
  • dougrainer wrote:
    Need Brand and Model of Oven. There is a non published TSB on I believe Atwood ovens where the problem is what you describe and it involves replacing the Pilot assbly. NO adjustments would fix this problem. Doug
    Suburban SRNA3, sounds like this is not an issue for mine, but thanks for mentioning it. I did hear about some recalls for my brand but havent found anything specific.
  • Darryl&Rita wrote:
    Thermocouples either work, or they don't. The nut holding it to the gas valve may be loose, causing intermittent loss of connection. Use a wrench to just snug it up.
    Thanks, I did that as part of the troubleshooting steps following the other threads, no change after doing that.
  • Old-Biscuit wrote:
    Nice that you have a pristine 2014 !
    Brand/Model of stove/oven would be more helpful to resolve your issue
    Could be low LP Pressure (oven have their OWN LP Reg set to 10"WC under stove top cover)
    Could be pilot light issue
    Could be thermocouple and or connection
    Could be....
    Brand/Model ???
    Sorry, totally should have mentioned that.
    Suburban SRNA3SBBE
  • Need Brand and Model of Oven. There is a non published TSB on I believe Atwood ovens where the problem is what you describe and it involves replacing the Pilot assbly. NO adjustments would fix this problem. Doug
  • Thermocouples either work, or they don't. The nut holding it to the gas valve may be loose, causing intermittent loss of connection. Use a wrench to just snug it up.
  • Thermocouples can go bad. You can buy them at HD or Lowes. Take the old one so you get one of comparable size and length. They are cheap and only take a few minutes to replace. Nothing fancy about them, they convert heat to milliamps to keep the valve open.
  • Nice that you have a pristine 2014 !
    Could be....
    Brand/Model ???
