Chris_Bryant
Dec 04, 2016Explorer II
srd1941 wrote:
OK here is a follow up on my Wedgewood oven: there is a slotted screw behind the control knob. According to the manual it is only to adjust the pilot light, not the burner.
That is the temp adjustment if it is in the shaft, the pilot adjustments are to the side- under the knob, but not in the shaft.
When I adjust those, I set the temp at 300, let it run for a while, then see what the actual oven temp is- then I hold the adjustment screw stationary, and turn the shaft to about what the right temp is.
Easier to do than describe, but I just about guarantee that yours is adjustable.
