CarnationSailor
Jun 01, 2017Nomad
Oven Won't Maintain Temp
Our 2.5 year old, lightly used, Suburban oven won't maintain the set temp. It heats up to about 50 to 75 degrees above set temp (no big deal, to be expected), then the burner and the pilot go out instead of the burner reducing to a minimum flame and the pilot remaining lit.
I have read posts on the forum, but not actually found any with the same symptoms. As suggested, I checked the alignment of the pilot and the thermocouple, and the thermocouple appears to be directly above and parallel to the pilot tube. I also cleaned the thermocouple with emery paper. I even switched propane tanks thinking one might not have been properly purged of air.
I'm ready to call a tech unless someone can suggest something else to try.
Thanks.
Thanks.
