MEXICOWANDERER
Jun 20, 2018Explorer
Electro chemical is impossible to control without utilizing 15 sensors. Without sensors plug and play is all focused and based on asssssssssumption. 99.00000000% in error.
The psychosis of algorithms is one of the largest battery killers in history. Only a purposefully ignorant user of manual controls is worse. But then looking at obituaries, I see the result of purposely ignorant drivers of automobiles.
The problem Jim@HiTek is there are few if any OPTIONS to gain analog control of battery charging. The industry is learning but far too slowly.
Have no worries about freeze-face sneering the other 50% of the time I am laughing.
"Stand in front of kiosk. The menu will guide you through your DOCTOR KIOSK algorithm examination. At the end, the kiosk will dispense needed Rx if any."
Absolutely agreed about component selection. Why do they even select 85c minimum voltage electrolytic caps and borderline rectifiers in a power supply? Frank Oropeza made millions of dollars at Transpo electronics designing voltage regulators that used FETs, sold them for 1/10th the cost of OEM and they had superior performance and lifespan.
Now we're back to CHEAP AT ANY PRICE with no alternatives...Hwang Ho, minimalist.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
